I am considering buying some Superstar Components Ultra wide wheels, which have a rim internal width of 19mm. I plan to use 25mm tyres, but a see that both Continental and Schwalbe list the narrowest width tyre for a 19mm wide rim as 28mm. The widest rim they recommend for a 25mm tyre is 17mm. Has anyone used 19mm wide rims for 25mm tyres? Any issues? I am lightweight at only 65kg!
5 comments
dave atkinson [6483 posts] 3 years ago
they're correct in that ISO 5575 covers rim and tyre combinations and in theory a 28mm tyre should be the minimum for a 19mm internal width rim:
https://en.wikipedia.org/wiki/ISO_5775
having said that, i've used 25mm tyres on 19mm and 21mm internal width rims for thousands of miles with no issues at all, and i'm 91kg. so i don't personally think it's much of an issue
pcaley [42 posts] 3 years ago
OK - thanks for that I now understand why they are all saying the same thing. I must admit I had not anticipated that an ISO standard would recommend tyre sizes for given rim widths.
frankierae [18 posts] 3 years ago
Hi, completely agree with Dave about the compatibility of 25mm tyres on larger internal rim widths.
I've always considered the ETRTO recommendations baffling. Imagine how unstable cornering a 37mm tyre would be on a 17C rim (a recommended pairing), whilst  a 23mm tyre doesn't even make the cut! 23mm on 17C is a very common pairing when buying a new bike. Cervélo S5, anyone?
I'm a 95kg Clydesdale and recently upgraded from Fulcrum Racing Zeroes (15C) to HED Ardennes+ (20C) for exactly that extra width and tyre volume. I use 25mm Conti GP4000S and they were decidedly light bulb shaped on the Zeroes. Squirmed around a lot at 85PSI (my preferred pressure for comfort, since the rims themselves are rock hard).
Now on the Ardennes+ the tyres have super straight sidewalls. I've settled on 70PSI after a few months of trying and find it to be really comfortable, yet less squishy while cornering. There's less of a whirring noise while riding too, which I suspect means less deformation. Certainly the setup feels faster (however I won't offer that assumption). A sidewall aligned with the direction of load will support the load better of course.
I actually feel that 20C is perfect for a 25mm tyre
The only downsides I've found are a) the tyres are so wide now I have about 1mm clearance from the chainstays (frame dependent ofc), and b) the Ultegra brake calipers only just open far enough for the rims and I get the slightest bit of brake rub. Currently waiting for a bit of wear to make more room  1
Hope that helps!
mikesm08 [1 post] 9 months ago
COOL, do you guys think then 25mm clincher will be just fine on this rim?
Anyone know if I could squeese it into my cannondale supersixevo 2014, 52cm?
It might just, according to  Frankierae's pic
Vejnemojnen [289 posts] 9 months ago
you can even choose 23mm tyres. Those will spread out to cc. 27mm on wide rims.
IMHO, anything wider than 25mm on a 19c rim is not optimal for handling and cornering
