7 comments
I have just seen the page on the link below which gives a comparison between stainless steel, optislick and polymer coated cables. Certainly looks like stainless steel is the least good option. The only remaining question is whether the end ferrules in those gear cable sets will be OK with 5700.
https://bike.shimano.com/en-EU/technologies/component/details/optislick....
Thanks for your replies
Crossed or not, many modern bikes suffer from poor shifting with standard ss inners. Even when indexed correctly, they are far from smooth and operate on a tiny margin of error. As it varies from one setup to another, your Tiagra 4700, which BTW comes originally with Optislick inners..., may work better than the OP's 105 which still doesn't change the wider picture.
There is a good reason why Shimano started offerring high end inner gear wires;-)
I guess I've been lucky - £3 Lifeline specials inners and outers plus three barrel adjusters in the rear run
Under the tape (vanity) routing will always have more friction and many (not all) 10sp+ setups won't index correctly or will feel "wooly" with standard gear wires, even on new bikes (based on often frustrating workshop experience).
You may need Shimano Optislick or even better Polymer coated wires to get it to work smoothly.
I always set my shift cables to cross under the downtube, helps open out the outer radius from shifter to downtube cable stop. No shift issues if well-maintained, even on Tiagra 4700.
OP - good ferrules and barrel adjusters can make a difference, as do well-finished cable ends.
Thanks for your reply. I did that before I put them on and operated the shifter with a cable installed which was pulled tight and all seemed fine. This is what leads me to think it is the cables.
Considering you don't experience issue shifting to smaller cogs it possible your shifting issue is why the seller sold those shifters? Perhaps a little lube in the shifter mechs may help.
