Chain Skipping. Help appreciated!
Hey all, long time lurker, first time poster, I've looked everywhere for a solution to my problem!
I was going up a hill putting a large load through my Cannondale CAAD12 the other day when the next thing I knew I was on the floor (a lot of pain but that's another story!) with a snapped chain. I should point out I fell quite hard and the bike could well have taken a few knocks.
I had, as it goes, cleaned my bike that very morning and measured the chain. The chain was NOT worn anywhere near the 0.75 point, and when I looked at the chain, the pin had become detached, so wear of the chain was not the issue in my opinion, which is key to what comes next
I took the bike to decathlon and they fit a new 11 speed chain for me, and confirmed that in their opinion the cassette was not worn. When I started cycling, I noticed that the chain would "skip" and by skip, I don't mean that the chain was going between gears, but that instead the chain would click and it was like it wasn't transferring power at that time. It only skips on 2 gears, the 3rd and 4th "easiest" or "largest" on the rear derailleur, fine when not in these two.
I took the bike to cycle surgery and the guy said I had a bent rear hangar, which he was able to sort there and then, but it still skipped, at which point he started saying "it must be the cassette" which in my opinion was just laziness, he was in a hurry and didn't have more time to devote to the bike so I understand what he is saying but I really don't think that's what it is. I understand about chains and cassettes wearing together but the chain was still below 0.75.
I should point out that the chain and bike have only done approximately 2000 miles in total.
Does anyone have any ideas?
Thanks in advance!
15 comments
risoto | 5 years ago
You could also buy a 105 cassette, a bit cheaper than ultegra. I disagree that more expensive parts lasts longer concerning group sets. Dure Ace and Ultegra are made to be as light as possible. They may also be a bit more precisely made to secure smooth operation, but I do believe they wear out faster. Weight and durability seem to go well together if you ask me.
Perhaps your bike came with a cheap chain that has worn out the cassette faster? The chain had a problem with a pin which might also have contributed to some kind of imbalance between chain and cassette. . Did you buy a quality new chain at Decathlon?
Wear and tear depends on many factors. My Bianchi didn't come with the best chain around. I rode about 4,500 km's and the cassette needed to be replaced (which was an original Veloce). I bought a KMC chain, well one of the cheapest, just replaced it after about 3,000 km's. 'Park tools said 0,5 but not too far from 0,75)'. This time no problems whatsoever with the cassette. Was it because I replaced it earlier or was it because I started to simply wipe my chain with wet wipes, or just a dry cloth, after every, almost every!, ride on this second chain? Nobody will ever know.
Hope you are a happy rider by now!
ktache | 5 years ago
Nice to hear thats sorted Hussavik. I don't know if you should have headset spacers rattling, they should be under a bit of pressure, Park Tools excellent website gives excellent advice on setting up headsets on https://www.parktool.com/blog/repair-help/threadless-headset-service  , parts 8 and 9 for this.
On one of the pages there is picture of a bike, and you hover over the bits you want to sort.  Their method for fine tuning cup and cone wheel bearings made it so much easier for me.
And theres always Sheldon Brown if you want to know everything.
Hussavik | 5 years ago
Hey guys,
Bit of a late night mechanic session, I fit the new cassette and took it for a 3 mile test. It WAS the cassette after all! I feel pretty silly now, but very happy that it is all sorted, and glad I managed to do the mechanical side by myself.
Now I just need to stop my headset spacers from rattling so much and I have a 100% bike!
Thanks again everyone.
shufflingb | 5 years ago
Chain snapping, had a similar thing with a pedal axle snap, unpleasant, sympathy    ...
I think, it does sound like the cassette might be worn. However, one other thing that might be worth a shot is to check the B-Post tension is correct. Putting a new chain on could well have upset that setting and if there is not enough chain wrapped around the cassette it will be more likely to shift badly and slip under load.
huntswheelers | 5 years ago
The danger changing just the chain is skipping, as has been said much of the skipping is on 2 or 3 sprockets, the most often used ones. Ultegra/Dura Ace are sets where when I change chain/Cassette combo to save customers returning....and .....often if you run your fingers gently over the sprockets you'll feel "sharp" edges, rather than "squared" ... I've even seen teeth which resemble shark fins...... The only grumble I get is the cost of changing cassette/chain combo, I just have to explain the components are lighter and often a softer material...... Wait until you have to explain a SRAM Red single block cassette needs changing.... ugh! ....
Hussavik replied to huntswheelers | 5 years ago
Thanks a lot. When I first heard it could be the cassette I looked up the dura ace one and saw it was £150 and nearly had a heart attack. When I realised k was using ultegra and it was "just" £50 I felt a lot better. I'll get a different tool that will meausre at 0.5 too.
I must say I am reassured by the comments on here that it hopefully is the cassette, even though none of the teeth look like shark fins yet. I think I need to fully reindex the gears as well as it struggles to stretch the full 11 gears across both chainrings (not that I do that when on the road! Just in the stand)
Thanks again everyone, this is a great community and a hugely valuable resource to someone like me!
Dnnnnnn replied to Hussavik | 5 years ago
A 105 11sp cassette would also work, wouldn't it?
Hussavik replied to Dnnnnnn | 5 years ago
Yeah it would. Another thing I didn't realise at first, but then decided I would replace like for like. I'm kind of doing everything for the first time, but with resources like this and YouTube videos, it's the best way to learn!
The cassette has been delivered, I'll fit it today or tomorrow morning!
VeloUSA | 5 years ago
I use Park Tool recommended chain replacement rule:
10 speed or lower system replace chain @ 0.75%
11  speed replace chain @ 0.50%
Jack Osbourne snr | 5 years ago
Could be a worn cassette and if it only does it on a couple of sprockets (the ones you probably use the most) it is most likely down to that.
It could however, also be due to a sticky or stiff link in the chain, which is an irritatingly common issue with new chains (about 5% IME)
To diagnose this, put the bike in the workstand and turn the cranks in reverse. The chain will skip or click at the rear mech & cassette and/or the chainring when the stiff link enters that section of its revolution.
madcarew | 5 years ago
It does sound like a worn cassette / sprockets, but I disagree that 2000m is enough to wear out a cassette / sprocket. Most of my cassettes last 6-10 chains which is about 30,000km before any issue of skipping begins. However, if the derailleur is straight, and the pivot pins aren't bent (if there is damage in the elbows of the derailleur, it can go out of line as it moves along the cassette), and the hanger is straight, and the gears have been tuned from zero, then worn sprockets is pretty much the oonly possible issue left.
Hussavik replied to madcarew | 5 years ago
Thanks again for the help guys.
I am relatively new to all this but need to learn to check this derailleur and pivot pins, hopefully there's some instructions online, but I hope that the guy from the bike shop who eyed it over would have noticed this.
Guess it's a case of waiting for the cassette now!
hawkinspeter | 5 years ago
Sounds like a worn cassette to me. Skipping on just the most used sprockets is definitely a symptom of new chain and old cassette.
Get the cassette changed and keep the old one in case there's no difference (i.e. the old cassette wasn't too worn). Another possibility is if the cassette hasn't been tightened sufficiently, though that would most likely cause issues with changing gears as well.
Dingaling | 5 years ago
2000m or 3200km is easily enough to wear out sprockets. It is perfectly normal for just one or two sprockets in a cassette to wear significantly more than the rest and what you have described indicates to me that you have been using 3 & 4 ( a lot) more than the others. There is one other aspect here and that is the quality of the cassette. Generally speaking, the higher the price (better groupset) the better the quality and the higher the mileage. You wrote that the bike is 2000m old so I understand that the cassette is the the one that came with the bike. A common trick manufacturers like to use on new bikes is to use higher value components that a buyer can easily see and compensate with lower value components, like a cassette, that are not so easily identified.
Hussavik replied to Dingaling | 5 years ago
Thanks so much for your reply! The cassette is an ultegra and most components are dura ace. I've bought a new cassette on its way so will try and fit that when it arrives and report back!
