8 comments
5800 series and above will easily clear a 28mm tyre, if your frame is compatible. 5800, R7000, R8000 all mid-drop calipers
Miche do very good long-drop calipers at surprisingly low prices. I've been running them on my everyday bike for seven years and they are truly fit-and-forget. And, as they are owned by Campag', you will be blessing your bike with a touch of Italian magic.
I thought the Miche long drops were a bit meh, not great but not bad either, I moved them on because they were no improvement over the A550s I had. The Miche were silly money though, I think I saw them around £15 a pair at one point and £20 the pair was common place. I've been out on my retro bike today and with non aero levers was still able to pull up fine with a pair of A550s from around 30mph.
I bought some of the TRPs and will likely be using them with an 11 speed for the rear plus a 10 speed triple. If I find that there's some lesser braking I might even swap them around.
As for Miche/Campag, Miche produces the vast majority of their kit in Italy, Campag outscources, they've had a relationship for a very long time with Miche producing for Campag (among many other famous names) but I didn't know there was a buyout, are you sure?
Even though it was released in the 10-speed era, Shimano now list the BR-R650 on their website as part of the 105 5800 series...
https://bike.shimano.com/en-EU/product/component/105-5800/BR-R650.html
If you want to confirm compatability, check out the official Shimano compatability chart here:
https://productinfo.shimano.com/#/com?cid=C-453&acid=C-456
Section C-456 covers road brakes.
All modern 11-Speed levers will work with their long drop brakes:
BR-R650
BR-R451
BR-R450
BUT, the compatibility chart says performance is slightly reduced, or be be exact "Braking power is slightly less than standard combination".
Shimano hasn't bothered to release new long drop brakes since the 10-speed era as far as I can tell. The pull ration slightly changed with the move to 11-speed era (Dura Ace 9000 released in 2012); not enough to prevent safe function, but enough to slightly impact braking.
All shimano long drop brakes are rated to 57mm drop max, so if one fits they all should, the only difference if weight and finish.
Thank you all for replies and advice
Shimano R650 are pretty awesome and should do 57mm quite happily I think.
Probably the best long-drop calipers are the TRPs. I got a pair of TRP RG957 calipers from FleaBay a few years ago and though they're expensive (got them for £99), they work so much better than the Tektros that were on my old Synapse bike.
Here's a review of them: https://road.cc/content/review/115645-trp-rg957-deep-drop-brakes
Looks like they're a bit cheaper than RRP from Sigma (£107): https://www.sigmasports.com/item/TRP/RG957-Dual-Pivot-Long-Drop-Caliper-Brake-Pair/75Z2
Probably best not to ask the box-shifters. Tiagra is a shallow (39-49mm) drop caliper, as are BR-R561 / 105 etc. Poor show from Madison, too.
SJS Cycles will be more helpful, they describe their stock and answer questions accurately. Shimano BR-R650 is probably what you should be looking at and often cited as the benchmark for longer drop brakes:
https://www.sjscycles.co.uk/brakes/front-shimano-brr650-caliper-brake-de...
Also listed in SJS's caliper brake category (which you can filter by drop, which makes sense) are Tektro R539, a good performer.
