9 comments
Turns out I snapped part of the cassette (a spacer I think?) Towards the larger end of the cogs, ultegra as well, fitted in April, pretty disappointed! New cassette, and getting a new chain at the same time.... Thanks for all your help everyone!
Did that not used to be one of the main differences between Dura-Ace / Record cassettes and the rest: the former fully engaged and so pressure and wear on the freehub was evenly distributed, but the cheaper versions only partially engage so damage alloy freehubs in particulary. Still, quite a job to sheer it off!
Has your cassette got a carbon spider? It has probably snapped
Freehub, or cassette. The easy gears come in groups of 2 or 3 and are plastic mounted on a spider frame, they could of snapped off the teeth.
How often do you service the bike?
Thanks a lot for all your replies, will take it to the bike shop tonight on the way home as it looks like it will need something a bit above my experience!
Thanks again everyone!
Remove rear wheel. Remove lock ring (sounds like you will probably be able to do this by hand). Answer there will come.
The last couple of "cogs" are seperate. Mybe the locking lugs have sheared off or the lock ring has come loose and they are spinning.
It sounds like your freehub body or the cog/hub interface has worn out.
You'll have to remove the cassette to see if that is the issue, suggest a trip to the bike shop to see what's what and get new parts, which it sounds like you will need.
Most likely sheered/mashed clean through the aluminium hub splines, or potentially snapped the freehub body in a very clean and straight break (seems unlikely).
Cassette sprockets tend to be steel and fairly tough.
New freehub body I expect.
