11 comments
If this is Atrial Fibrillation, you are putting yourself at risk riding a bike without it being identified and treated, so please go and see a doctor to get it ruled out or confirmed. AF can be symptom-free
If you must ride in the meantime, what happens if you wear a chest strap and use no lights? If you're still getting occasional high heart rate reported on an HRM, I really don't believe this is caused by car headlights. 230 is highly unlikely as an actual HR unless you are under 25 and really pushing.
I've never experienced such interference in years of running and riding with Polar, Sigma and Garmin. The closest is irregular readings during max HR tests which I put down to chest movement - but that was occasional beats missed by the HRM, not extra beats.
Never seen this using my Wahoo Tickr strap or wristworn Garmin forerunner.
Another vote to go and speak to your GP. Had high readings just before Ride London 2 years ago and it was AF. Again, several procedures later, symptoms gone. Hence, have high confidence in Garmin strap and 520+.
Are the AF spikes accompanied by any other symptoms? For me it's only when I download the data that I notice.
It’s certainly possible it could be electrical interference, but if it’s happening regularly and with two types of monitor, I would take the above advice and get checked out by the docs in case it is AF.
It could be a poor electrical contact with the skin, so try some of this on the electrodes.
https://www.amazon.co.uk/Sonogel-GELE100-Electrode-Gel/dp/B00BZ4SMOQ
I had sudden unexplained spikes of this level and blamed the monitor for a couple of years. After a while, when it worsened, I discovered that it was a heart condition called Atrial Fibrillation. After two heart ops and two years of taking it steady, I am back to normal.
I'm normally riding 10+ hours a week and always wear a Garmin strap. Generally the only time I get odd spikes is when it gets too dry to contact the skin properly. I normally put a little bit of spit on the two pads as I put it on just to make a good contact. Once I work up a sweat its fine unless it’s a very dry cold day then it can give big spikes as it loses contact.
The only other time it went haywire was when the strap was giving up. If you think it might be the strap don’t bother with a new Garmin one, just get one from Amazon for £7
https://www.amazon.co.uk/gp/product/B06WLMMG7S
I get the same issue when running. I believe that it is because the strap itself becomes saturated and starts to slip slightly causing a double reading. Try either tightening the strap or moving it up or down slightly.
A watch that measures heart rate on the wrist (with a "laser") shouldn't suffer from electrical interference, so you could look at getting one of those.
Hmmm, I don't know. Never experienced this with my Garmin chest strap sending data to an Edge 1030 while riding with my light set on either pulse or fixed + pulse. But I'm not familiar with the technology used and if it is theoretically sensitive to this type of interference.
