4 comments
You need to check the lockring isnt pressing against the bearing face when tight.
It could be the lockring needs slightly filing down in thread length or a different make of lockring. It might on need 1mm or less to stop the drag on wheel rotation- never experienced this myself.
Thanks for the advice. I've had a discussion with Hunt now, and it looks like my wheel is accidentally missing a red washer thats some sort of spacer fitted between the freehub and the shell.
It would make some sense that if this is missing, then the force generated by fitting the lockring might be putting a little bit of compresive force where it shouldn't.
The red washer is on its way, along with a replacement lockring (just in case). I'll update this when I've sorted it...
Tighten the rotor, then adjust your caliper alignment by loosening the bolts and either use spacers on the rotor or (my favoured method) an elastic band on the brake lever to align the calipers to the rotor.
Unfortuantely as I said, it was doing it when not fitted to the bike. Although the rotors didn't appear to be rubbing, I re-aligned them anyway using a birzman clam. So that wasn't it.
In the end I seem to have fixed it by swapping the rotor lockring for an identical one off my other set of wheels.
No idea why that is...
