6 comments
Completely forgot about this!
Thanks for the advice all. I have actually set up tubeless numerous times, but few on road rims, and wondered if there was any new-fangled tape de rigueur with those in the know. Kapton tape seemed to be popular a few years ago now but gone out of fashion. At least it was a cheap failure. What's funny is the tape failed on the first spoke hole past the valve so there was actually THREE layers of tape on that point!
Guess I'll just go with Stan's
@hawkinspeter: I thought you were supposed to use tape either the internal width or not much bigger, much like Spangly Shiny above recommended 20mm tape for 17mm id. I'd say you were using tape too wide - but I'm no expert and if it works it works
Next time I get some, I'll try the thinner tape and see if it's easier.
Stans tape two layers will prevent rim blow out permanently
I must admit to being confused about rim measurements and which tape size to go for. I've got Prime RP50 wheels which are listed as 16.5mm internal and 25.00mm external, so I went with the 25-29mm tape. The tape seems to fit really well as it sits across the edge of the rims until it's pulled tight against the rim bed, so it more or less covers the entire width.
For a 17mm ID rim use 20mm tape. Any of the tubeless specific tapes will do. Pull tightly on the tape and feed it into the wheel well as you go. Give it two full turns around the rim starting and finishing opposite the valve hole.
Haven't heard of that happening.
I've got a MTB that only gets occasional use these days and I don't get any problems with that apart from needing inflation.
I use CaffeLatex tape: https://www.wiggle.co.uk/effetto-mariposa-caffelatex-tubeless-tape/
I went for the medium size which will probably be about right for your rims, though I don't know for sure.
It's like a plastic film that doesn't seem to stretch very much so I guess it shouldn't have a problem with being sat in sealant. I tend to use a couple of layers as I don't get the rims completely clean before applying which is probably not the best way to do it.
