9 comments
I have never experienced a broken chain, and for decades I 'got away with' the deprecated practice of pushing the pin out to the side plate and pushing it back in again, but I initially installed chains using the special Shimano pin that you snap off. I have now been through 4 chains with the 9 speed gravel bike, which came with a chain with a quick link. I bought replacement chains with a quick link and bought the tool. The has been no problem with any of these chains.
Thanks for all these contributions, sounds like it's a Campagnolo thing, not necessarily just because it's 11....
I think they could have at least left the joining pin already pushed in the outer plate on one side, negating the curious guiding start section which then snaps off, easier to just snap the sections together as well, with less of a "hold in place" initial step
I'm a bit confused by your apparent aversion to quick links. They seem to work well in my experience, and are probably more reliable than a chain tool split/join job.
They work well, until they don't
It was mentioned, I think by Pilot Pete, that putting a rivet out and then in results in a less strong fix, I presume that Campy's peening is just as strong as an unmessed rivet.
I'm not entirely sure what your question is, are you looking for information on how to peen the pin?
Hi
No, not at all, wondering why do all that when can just break the chain anywhere and rejoin with existing pin still hanging in the link, like I do with a 10 speed chain and chain rivet tool.
Like said, I never use those quick links either in other makes.
Thanks.
The rivets in the chains are not straight sided. There is a lip at each end to help keep the rivet it place so the chain does not snap. Removing the rivet breaks off this lip from one end. I often hear a snapping noise and see the thin metal ring in my chain tool after breaking a chain. So if you just push the same rivet back in to join the chain this would be a weak link. Different brands recomend different methods of rejoining a chain and the Campag method requires peening special rivet to form this lip.
Reusing the pin creates a weak link in the chain, the special pin, when properly peened, creates a link that's at least as strong as any other in the chain
