14 comments
Has there been some comments deleted from here? I recall stating something similar to Dicklexic, but it's no longer here.
Going off topic but how long will an unopened bottle of Shimano mineral oil last? I have a bottle which came with my mtb brakes about 12 years ago which has never been opened, will it still be ok to use in my new road brakes?
You should drink within at most 2 months of opening.
Ha! be lucky to make it last more than an evening.....
I wouldn't say 'indefinitely' but it's certainly a very long time. Shimano use mineral oil which is not hygroscopic, unlike DOT brake fluid. In fact it is hydrophobic so consequently it does not absorb moisture. DOT fluid is hygroscopic so any contact with open air will lead to moisture being absorbed from the air, and thus cause the brake fluid can boil if it gets hot.
Cool!
I did a bike groupset upgrade a year ago and had the same problem. I ended up using Shimano m6100 mountain bike calipers.
I will keep an eye out for these
mixing shimano and campagnolo would be bad as I understand they use different brake fluid.Campag levers would be compatible with sram calipers I believemy mistake, the calipers hope sell for use with shimano are the same as they would sell for campag. Thanks to others below for correcting this.
https://www.hopetech.com/products/brakes/road/rx4-caliper/
That being said both the fluid type and the volume transferred must be the same, so there should be no issues.
As long as the parts aren't used, would there be any difference in performance if you used different hydraulic fluid? (Not going to do it, but just curious on whether there's any practical reason that you couldn't run Campag on Shimano fluid and vice versa)
I think the seal material is specific to the fluid used, calipers and levers intended to work with DOT (SRAM) are not compatible with mineral oil (shimano/campag) and vice versa
Thanks - that makes sense.
Not quite. Shimano & Campag both use mineral oil. SRAM uses DOT.
No, that would be much worse than mixing Shimano and Campagnolo. Sram uses Dot fluid, the other two are both mineral oil.
Pic
I have the same v1 Definition and have been loking for something like this - which was the actual one you ordered? They have 140 > 160 and 160 > 160. I see Wolftooth now do one as well, but equally unclear ordering criteria.
