Indoor fan recommendations please
I'll finally finally get my permanent indoor training setup in a few weeks. Whilst the trainer will be next to a full size window, it will likely not produce much breeze.
What fans do folk recommend?
I'm looking for something with some power, as quiet as possible, and ideally a remote, all without having to spend £200+ on a wahoo fan.
Thanks....
4 comments
mark1a | 3 months ago
I've got a permanent indoor setup and have not needed a fan (it's in a garage so no windows either, but fairly cool at around 15 deg C in the winter months) just relying on the very small fans that are built into the bike. Maybe I'm not trying hard enough...😩
However one thing that has been essential is a dehumidifier, to prevent sweat and exhalation causing a build up of humidity, is that something to consider perhaps? The garage used to go up to over 80% after an hour on Zwift, the dehumidifier keeps it down to around 60%.
OnYerBike | 3 months ago
If "quiet" is important then how about something like this: https://www.meaco.com/products/meacofan-1056-air-circulator (available for ~£80 from reputable online retailers)? I daresay you can get more blowing power for less money by buying a geneic gym/industrial fan but they will be noisy.
bobbinogs | 3 months ago
I just use an industrial grade air mover, lot's of them to choose from but this was the one I went for (and it works really well):
https://www.machinemart.co.uk/p/clarke-cff18b100-18-high-velocity-fan/
stomec | 3 months ago
We have an Oypla floor "gym" fan - a big (50cm) one.  It is fairly quiet and I usually only need the first or second speed setting even in an intense workout.  It sit it on the floor under the bars pointing up.  I think there are on Amazon at about a quarter of the proce of the Wahoo one.  Has worked reliably for 4 years now with no issues.
