12 comments
Let's start with the obvious, you say that you are to the world of bikes so did you know that the left hand pedal has a left hand thread (ie turn clockwise to remove)?
new, but learning quick. Spent a lot of time reading and watching YouTube so I do indeed know that they thread differently.
Ok, sorry, I didnt mean to offend you
No no, I didn't mean to come across so blunt, just heavily frustrated at buying pedals and shoes that I can't use because someone with hulk like strength put the old pedals on!
Maybe they didn't know about the LH thread and jammed it on! I guess you tried leaving a splash of penetrating oil to work its way into the threads overnight?
The other trick that sometimes works is to heat up the crank arm. The idea is to get to work before the pedal axle heats up too, so that the crank expands before the axle catches up. If you are lucky this can also draw in the penetrating oil. Obviously no blow torches, try a hair dryer or hot water. All whilst being double sure you're turning the right way.
And, when you do finally put your pedals on, a dab of grease in the threads.
That's highly possible. Tried oil overnight but again no luck. Heat is a last resort and I don't want to damage anything by accident. I might try taking the crank arm off (when my tools arrive) and heating it that way, away from the bike.
Off the bike is definitely to be preferred. You can set the crank horizontal with the pedal facing down and leave a puddle of penetrating oil (there is often a slight depression) over the threads. As to the heat, sure, don't go overboard, you don't want to blister any paint finish on the crank. Anyway, crank arm wrapped in an old innertube and held in a vice (not compressing the knuckle end), a decent length 15mm spanner on the pedal, all the other tricks, if it ain't shifting then you're buying new cranks!
When you say 'several people' , are they all bike shop mechanics?
Not bike mechanics, but a mechanic. Last time I went to my local bike shop they charged me £50 to fit two things I gave them so I'm not too keen on having to go again.
Have you tried fastening the crankarm in a vice to get extra leverage, alternately you could drill out the pedal and get a helocoil type insert fitted. PM me if you want to discuss in more detail
Unfortunately I don't have access to a vice and really want to avoid drilling out anything.
If it's a Hollowtech BB/crankset - which it probably is then any Shimano left-side crank will fit. It might look slightly odd but it will be perfectly functional.
You can tell if it's Hollowtech by whether the inside of the crank arm is flush against the bottom bracket, or whether you can see as square spindle (which means it's a square taper)
The other option is just to replace the whole crankset - Sora or Tiagra aren't that expensive and it's a very easy job.
