Road bike purchase advice
In the next year or so I'll be turning 50 and I'd like to celebrate with a new bike. I currently have a steel Dawes Audax Supreme that I use for everything (Commuting / recreational use / the occasional event). I love the way it rides - it seems to be quite compliant and absorbs the imperfections on the dreadful road surfaces that we have in the South West. I'd like to continue to use this for commuting and also to experiment with bike packing in future.
What I'd like is something a little faster whilst retaining a comfortable riding position so I can do events such as the Dartmoor Classic. I guess that I am after a Endurance bike wha would people recommend? It needs to be under £3k and ideally on the CycleSolutions Cycle to Work scheme. I'd quite like 105 Di2 and think that a threaded bottom bracket is preferable to a press fit bottom bracket. I should say that other than an old aluminium hybrid I haven't ridden any other bikes. So far I have considered:
Sonder / Dolan (titanium) too heavy?
Cannondale Synapse 2 (don't like the integrated lights as this is just something to go wrong and I'd rather sort out my own lights). I am slightly nervous about the lifetime / robustness of carbon bikes.
A friend of mine has suggested a Cannondale SuperSix Evo3 but this sounds way too racy / not sufficiently comfortable.
Thoughts?
Mark
13 comments
Jimthebikeguy.com | 4 weeks ago
Try and get rid of the negative associations around carbon and pressfit. Carbon frames are no more troublesome than metal, and pressfit is no more or less difficult to work with than threaded.
Then go and buy a new shape giant defy.
Aluminium can | 1 month ago
Focus Paralane has threaded bb and endurance geometry. Available in your price range 😉
Plan B would be to just get a second set of wheels for current bike. Fit one with race tyres and the other with puncture proof. It's amazing the difference tyres and wheels make.
Surreyrider replied to Aluminium can | 1 month ago
Problem with the new Paralane is very limited availability. It was on my long list but hasn't made it to the short list due to that.
Simon's Two Wheels | 1 month ago
Sonder Colibri.
https://alpkit.com/collections/sonder-colibri
Don't fixate on weight, just enjoy the ride, which on Ti is sublime. Here's mine.
Surreyrider replied to Simon's Two Wheels | 1 month ago
Equally, you could say don't fixate on the frame material - both ti and carbon can be made comfortable or stiff.
Richbeck | 1 month ago
Take a look at spa cycles - plenty of choice and options.
Daveyraveygravey | 1 month ago
So many choices! Have a look at Fairlight, and also Mason.  A lot of Mason bikes are over £3k but they make steel and ally ones that you should be able to get for that.
I wouldn't focus on DI2, yes it's nice, but its a compromise that would effect the frame and wheels, which most people say are the most important areas to focus on.
I have a Giant Propel which has been my road bike for 9 years.  I still get a kick out of riding it, but it's not great in winter on the roads we all have to put up with.  Road cc ran a story on using a gravel bike as an all rounder & winter machine.  They picked a Specialized Diverge, and almost on the strength of that story, I started to look for one on Ebay.  I managed to find one for £1200 not too far away from me, and it is a fantastic machine.  It was set up for off roading, so came with 45mm knobbly tyres.  I switched them for 35s, put mudguards on and just wish I had gone this route a lot earlier.  There's a little suspension movement in the headset, 20 mm, and this coupled with wider tubeless tyres, the compliance of the carbon frame, makes it a joy to ride when the conditions are not ideal.  Disc brakes too.
Npowel | 1 month ago
I ride a Cannondale SuperSix Evo, and I can confirm it’s racy but surprisingly comfortable for long rides if you dial in the fit. For your needs, the Cannondale Synapse 2 is a fantastic endurance bike can check here https://ebiikesshops.com/—less aggressive than the Evo and great for rough roads.
Simon E | 1 month ago
A SuperSix is definitely not an all-rounder.
Bikes like the Defy, Synapse and others described as 'endurance' would be a good starting point. Boardman and Cube offer excellent VFM. Ribble have already been mentioned.
Other brands will have similar models. One thought is that for a do-it-all bike you might want to look at something even less racy. The Fairlight Strael has lots of fans, though it'll be more than £3k if you want Di2. And there are the all-road, adventure and gravel models, with bigger clearances which will allow for mudguards and/or wider tyres for greater comfort. Cannondale Topstone, Trek Checkpoint and Sonder, for example.
I wouldn't ignore aluminium / alloy frame bikes such as Giant Contend and Trek Domane AL. You get more bike for the money and would have some left over for upgrading wheels or other items and accessories.
Look in the reviews and buyers guides sections of road.cc for ideas.
quiff replied to Simon E | 1 month ago
I was going to suggest the Fairlight Strael too, and went to check if it came in on budget. While there, I finally ordered the frameset I've been hankering after. Merry Christmas to me! yes
Mr Rodgers | 2 months ago
My money would go to the Giant Defy range. The Mrs has a 2023 model last year which has 105 di2, capably handled bike-packing LEJOG, and has lots of room for easy modifications (stems, wheels, tyres etc). They seem to have managed the best combination of speed vs comfort to my eyes (and derriere), and if you google some reviews you'll see others agreeing. It really is a fantastic bike, and when it came to getting a new bike for myself (after it was stolen) I've had to spend significantly more on an equivalent brand just to avoid having the same bike - sigh.
A 2023 model will get you well under the 3k mark with a high spec if you're content to have a bit of exposed cabling. It will be carbon, and I note your concerns around longevity, but would counter that its come a long way in the past ten years and personally I feel you shouldnt discount bikes on this basis.
I agree with your assessment on the Supersix - this is a pretty aggressive racing bike and, whilst lovely, I dont think its really what you're looking for from the description.
I'd recommend test riding a Defy, most LBS's stock them, to dial in the right size for you (Giant's often come up a little larger than other brands in my opinion). I dont think you would be dissapointed.
Surreyrider replied to Mr Rodgers | 1 month ago
Beware though, the new Defy models are more aggressive than previously. Getting quite close to the TCR now.
I had a Defy and found it comfortable but uninspiring.
The Supersix Evo is actually not that aggressive for a race bike, although still not endurance geometry.
Rendel Harris | 2 months ago
It's obviously a very personal thing but if I was in the market at your budget I would take a serious look at the Ribble AllRoad SL Pro, currently at £2699 for 105 Di2 groupset with Mavic Cosmic wheels and 32mm tyres. Threaded bottom bracket too!
