9 comments
Ok thanks for the reply's, I'm trying to work this out if the new caliper isn't compatible with the old hose I need to replace the hose as well but then won't I have the same issue with the new hose fitting the old break?
Sorry fella, too busy ranting to realise you'd asked a question. Do you know the model of your brake lever? I'm 99.9% certain you'll be OK though.
I've been thinking about this some more, and did what research I could on it. Here are my thoughts:
Looking at the compatibility chart, every STi lever uses the same sub-brake lever. So that should mean you can connect a BH59 hose and a BH90 hose to the same brake sub lever- it shouldn't leak or fail or anything.
Reading around, the two hoses have slightly different internal gauges- the BH90 is 0.2 mm narrower, and was developed to give a more progressive feel to the braking.
So if you replace your brake caliper with a 8070 caliper, you should be fine with BH90 hose, however I don't understand why Shimano's charts don't show ST-R785, RS685 and RS505 calipers as compatible. It could just be an oversight? Might be worth emailing Shimano support about it.
I'm not sure because I can't find them in the line-up/comptability charts here
Looking at the spec pages
https://si.shimano.com/#/
https://bike.shimano.com/en-EU/product/component/ultegra-6800/BR-RS805-R...
https://bike.shimano.com/en-EU/product/component/ultegra-r8000/BR-R8070-...
they do use a different hose kit so that might mean it will be a faff to fit. Need someone with more knowledge of that aspect to help with a bit more detail.
It might be because Shimano's "RS" range are effectively "non-series" components designed to work with multiple groupset levels.
Fitting won't be an issue, the only thing to look out for is that the two hose types (BH59 and BH90) are slightly different gauges, and hence take slightly different sized inserts. One is gold and the other is silver, so if you remove the hose from the caliper you should be able to see what colour the insert is and buy the same replacement.
In terms of using the R8070 replacement caliper you'll be fine- connection is still an olive and insert (as opposed to a banjo connection which some of the MTB brakes have moved toward).
Hmm...actually according to the compatibility charts it won't work:
https://productinfo.shimano.com/#/com?cid=C-453&acid=C-456
This is one of those that I'd personally be happy to install it and see, but at the same time I wouldn't necessarily recommend someone else do that...
To be certain of compatibility, you could use the 505 caliper, which I've found available online:
https://www.bike24.com/p2141813.html?menu=1000,4,322
This whole hose thing is very confusing. Put me off doing a hydro upgrade for my (mostly) Tiagra level tourer as I couldn't work out which levers worked with which post mount calipers and hose sets.
It's this sort of thing that continually pisses me off about Shimano and leaves me baffled as to why so many people think it's brilliantly engineered stuff...I suppose it is, if you've never worked on your own bike before. There's constant revision going on which makes it nigh on impossible to have a toolkit to cover all bases, these hoses being a perfect example. Another case in point- there are currently THREE different threaded bottom bracket spline sizes, and that's just for road. Dura Ace requires a different size tool to Ultegra/105, which is different again to Tiagra. Which is a fucking joke.
Rant over. Apologies.
