6 comments
I have a Garmin 830 and notice after each ride is uploaded to Strava, if I get Strava to adjust the elevation it increases the initial value given by the Garmin, sometimes by quite a lot. It never adjusts the elevation down.
There's more info about this here:
https://support.strava.com/hc/en-us/articles/115001294564-Elevation-on-S...
I have a similar issue with my 830 on all of my rides.
Some of it I believe is down to firmware updates over months/years. GPS accuracy etc.
Currently just using GPS, Garmin is about 0.3 mile under compared to Strava (if Strava is even correct).
If I use a 3rd party speed sensor, Garmin gives an "over" reading, compares to Strava.
I think the best way to get Garmin and Strava to try and match, would be to use a speed sensor and manually adjust the wheel circumference setting within your 810.
You'd have to look at some wheel circumference charts, to get a starting figure i.e. 700c 28mm = 2130 or 2136 if you believe Garmin.
Or try a tape measure 😁
On ride home last week, with speed indicator on I noticed a lot of slower speeds than expected - would be reading at 24mph one minute and then 13mph the next.
Have never used a speed sensor with the 810, and didn't think I was....
But over lockdown I was turbo training and the trainer came with a combined speed/ cadence sensor which I installed on the bike. Last week in particular the cadence was very intermittent (I'm assuming speed too as they run from same battery). So embarrasingly I think the whole issue is because of the battery life on that, and GPS has still been tracking ride hence prefect trace on garmin/ strava. D'oh!
Replaced battery in speed/ cadence, have hard reset the Garmin and installed latest firmware. If you hear nothing again assume it was the battery haha!!!
Thanks for the suggestions
Thanks for the replies.
This morning was 2 miles out, and still when you delve into the route on strava/ garmin there are no obvious straight lines/ dropouts.
I've tried exporting the strava activity as a course and got the same mileage shown as recorded. Although not being a full paid up member of strava it had very reduced features.
Probably doesn't help that I only display cadance, heart rate and time on my screen - will add speed tonight to see if any obvious drop outs.
Will go with a hard reset this weekend, and see how I get on next week before I get in touch with garmin.
I've got an 810 and not noticed any more than a tenth or two variation on Strava mileage I do notice it drops GPS signal more frequently than it did,currently on GPS + Galileo. I did get lost in settings one time when I couldn't get it to connect to anything,but it mostly seems ok.
Have you tried exporting the Strava activity as gpx and loading as a course in Garmin to see if it shows any difference?
How peculiar... I have an 810 and there are occasionally variances but nothing like that. You can correct the mileage/elevation in Strava so you will book the miles you've done, but clearly it won't be correct on the Edge.
I would imagine that if it can't see the satellites properly it would flag a GPS signal lost error. Perhaps try a hard reset of the unit (though you will lose any data/settings) or email Garmin help who are normally pretty good at suggestions.
