7 comments
I have had a few prolems changing cables on SRAM shifters but usually they are OK. I hope I am not stating the obvious but make sure that you are in the smallest sprocket setting on the lever before trying to thread the new inner cable through and the other thng that makes a big difference is using a good quality stainless steel cable, the end of the cable should be nice and round on a new cable, a previously cut cable may have a slightly sharp end which can snag and stop the cable going through. SRAM cables are also slightly thinner (1.1mm diameter) than Shimano cables (1.2mm diameter) and it does make a difference. If you are using a cable which has already been cut try heating the cable with a lighter or mach until it glows red hot then quickly cut it with a good quality cable cutter, this gives a nice smooth end which should help the cable pass through. Finally, feed a cable in the wrong way (ie from the top of the shifter) just to make sure that the cable path is free from any obstructions.
Thanks for your post - I'd forgotten about the slight cable diameter difference with official SRAM ones. The tip about heating used cables before cutting is great too!
FWIW Campag cables are also 1.1mm, going back years.
I enjoy maintaining my own bikes and replaced the gear cables on my Shimano bike without any difficulty whatsoever. However when I needed to replace my gear cables on my SRAM equipped bike I was totally perplexed and ended up employing my LBS to do the task. Turned out to be a good decision as they identified a fault on one of my callipers whilst checking the rest of the bike. Would rather pay the modest cost to my LBS going forward, safer in the long term.
Fair point - I'm just much happier doing all maintenance jobs myself, I usually learn something along the way too!
I had a similar problem last month with my Force shifters, the cable came out with a bit of a tug (it was within the shifter that my cable was getting stuck) but I couldn't get the new cable back through.
I didn't try to take the shifter apart, I just tried for a few hours (over two days) to get the cable through. Pushing the old cable backwards through showed less resistance than pushing it through the right way. That also meant that I could get some grease through. I also sprayed some MO94 in there. Eventually I realised that there wasn't a blockage and just used a bit more force to get it through.
So my thought on it is that there isn't a blockage but that the routing of the cable isn't very good and it gets stuck at the point that it needs to go upwards.
Jogle, thank you so much for posting. Once I'd read about your experience and decided to perevere with just trying to force the cable through, I quickly managed to first get the cable through the shifter from the top, so like you said, presumably no blockage. Then with the help of some grease, WD-40 and using pliers to force the cable, I got it through the right way. So problem solved and significantly cheaper than a new STI unit! Much obliged!
