Rear Light
Looks like my old CATEYE has died.  I want a real beast of a light as I'll likely be riding well out into the road with surface degredation around here.  And I'd like it to be battery powered - proper batteries - not some USB charged excuse of a battery.  This is because, since retirement I ride at odd times and I just want to know that the Duracells will live up to their name and I've not forgotten to recharge the light.
It also needs to be rack mounted, I noted in the RL review all lights were seat post mounted.  Any suggestions?  I'm not in the shop that often these days so a bit behind the times / out of date.
11 comments
check12 | 1 week ago
just get a usb rechargeable light grandad
ReflecToes | 1 week ago
A friend of mine created a rear light called tailgator technologies that has an accelorometer in it to get brighter when you are slowing down.   My son and I use it and it works great!
ktache | 2 weeks ago
Knog do a rack mounted Blinder.
John N | 2 weeks ago
I really miss my old Monster CATEYE light (bounced out of the holder when I hit a pothole some years back), that took 2x AA batteries and could be relied on to last through a Winter.
I'll have a look at the ALDI option, but as luck would have it, I managed to get my old OMNI 5 working again.  And I'd better look for a spare just in case it fails again.
Simon E replied to John N | 2 weeks ago
Although the Cateye Viz series are rechargeable they do still use the same square bracket so will fit in the standard seat post and rack adapters.
Having been reluctant to switch from AAA Cateye rear lights I'm now a convert - the Viz 100 plugs into my PC USB socket and will be fully charged in an hour or so after a week of commuting (35-lumen Group mode lasts 11 hours while 20-lumen flashing is 70 hours). Improved output and lens design makes it far better than the older models, including the Omni 5, which is pretty weak by comparison.
OnYerBike | 2 weeks ago
Cateye still sell a battery operated, rack mounted light: https://www.cateye.com/intl/products/safety_lights/TL-LD580G/
Busch and Muller also have a couple of options, see e.g. https://www.sjscycles.co.uk/lighting-battery-rear/?brand=busch%5F%5Fmuller
I do have slight hesitation about recommending Busch and Muller lights (or any other StVZO approved light): the German standards seem to take a particular interest in avoiding dazzling other road users, which (while noble in intention) does mean you are unlikely to get the "beast" of a light you are after, especially if you want to be visible in daytime (any kind of daytime flash option would not meet StVZO standards).
Beyond that, I suspect you're looking at Amazon/AliExpress specials to tick your boxes - plenty of people report success, but I wouldn't like to place my safety in the hands of a brand I haven't heard of.
But you might have more options if you can be flexible on your requirements? I for one would not rule out rechargable lights - yes you need to remember to recharge them once in a while, but I would rather do that than constantly buy new disposable batteries. I would also note that there are various accessories you can use to attach lights in other ways (e.g. adapters that mimic seatposts; under-saddle mounts etc.) that might open up more options (battery powered or otherwise).
John N replied to OnYerBike | 2 weeks ago
I didn't see that as I was looking on the Cateye's U.K. page.  It's not the beast I had but it looks to be the nearest thing to it.  Now to find a stockist.
HLaB | 2 weeks ago
Before I switched to USB light I used a Smart Superflash they were alway talked of well on forums.
Hirsute | 2 weeks ago
Always have at least 2 rear lights for failure and safety.
To fix a light to a rack, easiest to have one of these, then you should be able to fit any light to it.
https://www.sjscycles.co.uk/lighting-spares/madison-universal-light-moun...
Otherwise use cable ties to the rack  - did this with a cateye TL LD 1100
wtjs | 2 weeks ago
Get with it! I've been using Aldi rear lights for 8 years now- they're all Micro-USB charging (no doubt they'll move to USB-C some time) and have never failed. They come as a pair with an equally excellent front for about £10-15. Just buy two if you think you might forget to charge or if you want insurance for a long ride in the dark
bob.sweet | 2 weeks ago
John,
My personal favourite is cateye AU100, but sadly no longer available.
For general advice, cycling uk webpage on rear lights is at, but sadly no rack munted ones. https://www.cyclinguk.org/article/group-test-battery-rear-lights
here is the road.cc rear light review. https://road.cc/buyers-guide/best-rear-bike-lights-cycling
I suggest keep it simple. Don't do ones with brake lights or radar. I tried one with a camera, it had a meltdown,.
I have one of these, but not on my normal night time bike. Rack mounted, 2xAAA batteries. You need the bolt holes at the rear of the rack.:  https://www.amazon.co.uk/Fischer-battery-Rack-Light-Orange/dp/B01ING0CZ0
There are some really bright ones out there. If you get chance ask what they are using.
Bob Sweet
