5 comments
https://www.roadbikereview.com/threads/replacement-fork-for-2016-supersi...
Cheers, I've been looking through old forum posts. It appears ENVE once upon a time made a rim brake fork that was 1 1/4 to 1 1/8th taper with 45mm rake offset, but it doesn't look like that's available anymore.
I have a Cannondale carbon fork from a CAAD10 going spare. Same tapered steerer. The fork is for rim brakes. It's a white one. If your interested I could let it go for a reasonable price. It was from a frame I scrapped due to a small dent in the top tube. The fork is undamaged.
Try phoning a Cannondale dealer - oddly I couldn't find a UK Cannondale distributor listed on their website, or Cannondale customer service, then at least you've ticked those boxes off.
Thereafter, you can fit some 3rd party fork if you get the dimensions right - which is making sure the steerer tube is the right size, was this a standard 1 1/8" steerer tube or something fancier (like Giant adopted an oversize bottom 1 1/4" steerer). Then it is a question of checking the dimensions to ensure that the rake and offset is similar to achieve similar handling (and it is designed for the type of brakes you have - not so silly these days with not just but other variants). You saw off the steerer tube to the right length, so that bit is not a problem. The headset fit to a fork is fairly standard, there is a ring that sits on the fork and the bearing interfaces with that so different headsets should match any fork of the correct dimensions.
So with care, you should be able to find something, whether it will perform as well is a bit of an unknown. A decent bike shop should be able to work out what to put in if you are unsure.
Of course, Halfords can't even fit a matching fork...
The Cannondale uses a tapered steerer that goes from 1-1/4″ to 1-1/8″. I've changed forks on cheaper, less integrated bikes before, but not something this fancy. Neither the local bike shop, nor the dealer I'd bought it from back then, had any experience putting aftermarket forks in, and they both recommended an internet forum search to see if anyone had any experience online.
