Moan: Constantly dazzled by other commuters
Anyone else noticed this year there's an increasing number of overly bright front (and rear) lights, or is it just me? My commute has an extended part over an unlit moor but mostly lit cycle paths and I'd say people have their lights on the wrong setting or pointing at eye level approx 50% of the time.
Maybe my eyes have just got more sensitive but I'm finding myself having to ask people to please turn their daytime strobe off as I can't see where I'm going.
32 comments
schneil | 6 days ago
I'm glad it's not just me that finds inconsiderate use of bike lights an issue. The main problem is how lights are sold. Most UK sold lights are on the lumens they chuck out, and cyclists are having the message of "be safe be seen" drummed into them. This means many cheap bright lights are sold that have very little beam control optics and just chuck their lumens everywhere. It also doesn't help that many light reviews (I'm looking at you road.cc) don't look at anti dazzle aspects of their lights. So at least once a week, I get dazzled by an inappropriate light  2
mdavidford replied to schneil | 6 days ago
To be fair, they do have their beam comparer tool, which helps you understand where the light will go. It does rely on the purchaser bothering to read the guidance, though, rather than just going "this one's brighter - it must be better".
Nighttrain123 replied to schneil | 3 days ago
The brightness isn't the main problem. Dazzling oncoming riders can be solved simply by dipping the angle of the beam. On my bike, I use the very high tech solution of manually rotating my light fwd and down on the handlebar. Such consideration seems below 90% of other riders, sadly.
mdavidford replied to Nighttrain123 | 3 days ago
With most lights, though, this approach will quickly lead to your light flapping loosely while pointing mostly at your front wheel.
andystow replied to mdavidford | 3 days ago
I have a couple of lights without well-shaped beams. I just use one hand to shade the top until I'm past the oncoming cyclist or pedestrian.
Unless they're pointing a bright beam at my face.
brooksby | 1 week ago
Has anyone else noticed the trend for dog walkers to wear those head-lights, too?
The ones right at eye level and dazzlingly bright so that they can see Fido's poos.
Hirsute replied to brooksby | 1 week ago
I have a couple of head torches, but they look like this
//images.uttings.co.uk/images/products/petzl_headtorches/zipka_std.jpg)
Nicely angled down so you can see where you are treading.
brooksby replied to Hirsute | 1 week ago
Mine has a hinge along the bottom edge for the same purpose. But so few dog walkers seem to either have that or can't work out how to use it...
Nighttrain123 replied to brooksby | 3 days ago
Most runners and walkers on the pitch black TPT near me do their best to wear matt clothing exclusively.
Even with a bright light, it's hard to see them against the dark background.
They then moan about being dazzled.
OldRidgeback | 1 week ago
Hmm, it's overly bright car headlights that bother me most TBH.
matthewn5 | 1 week ago
I've got dynamos running B&M StVZO compliant lights. They are bright, but they have a hard upper cut-off so they don't dazzle. They light up the road brilliantly too.
belugabob replied to matthewn5 | 9 hours ago
I have a B&M Ixon IQ on my commuter - it's is also STVZO compliant and very effective. If I stand at the end of my hallway and point it at the mirror, down the end, there is no dazzle whatsoever.
As usual, the UK are slow at adopting things from other countries,which just work.
wtjs replied to matthewn5 | 6 hours ago
The latest Aldi headlight has this and also the bar mount provides click stop movement left and right of the straight ahead position which is very handy for me
S.E. | 1 week ago
I have to protect my eyes with my hand sometimes, like I would do when looking something close to the Sun...
I'm trying to fix my light so that the most powerful beams don't reach above the horizontal (relativately easy to estimate by facing a wall). To me 800 lumen seem fine for the trails, the lowest setting at 100 lumens is enough for the city, just to be seen.
I had the same issue with early car LEDs, it was just painful for my retinas to drive at night...
I've later found studies describing how LEDs can damage retina cells, even at powers used for indoor lightning!
CyclingGardener replied to S.E. | 1 week ago
My very first LED front light - a present, so possibly expensive - proudly stated that it was visible half a mile away or something, then in the next breath 'Do not look directly at the light as it could damage your eyes'. I can remember thinking at the time that this was fine for me, sat behind it, but a bit hard on the poor b****r coming towards me!
As LEDs have become more common everywhere, I've often wondered . . .
bensynnock replied to S.E. | 1 week ago
I'm not sure that 800 lumens is enough for a pitch black off road trail. I switched from an 800 to an 1800 and now I can actually see where I'm going in the forest.
S.E. replied to bensynnock | 5 days ago
I'm not doing single track (no suspensions, only 30, 35 mm tyres) so 800 lumen is enough for me, on gravel type of trails at maybe max 20-30 km/h, less if needed.
I'm kinda minimalist... or maybe just cheap...
Matthew Acton-Varian | 3 weeks ago
I have a fairly powerful front light, owing to the fact I do go on and off road, and sometimes in total darkness. However I chose one with various output settings, and I almost exclusively use the lowest setting anywhere that visibility is aided by street lighting. I also check the beam position every time I use it. But I can understand that the faff might be off-putting for some more casual users.
brooksby | 3 weeks ago
I appreciate that it is coincidence and confirmation bias, but in the last couple of evenings I've actually had to stop on a couple of occasions until the oncoming cyclist has passed me (as I couldn't see a bl**dy thing beyond the glare of their headlight).  Roughly the same place, too: my commute is on a narrow shared-use path, and if I can't see but move over anyway then I run the risk of getting tangled in the ivy on a wall my left.
Slartibartfast replied to brooksby | 2 weeks ago
I've just taken to shouting (as has my 6 year old cycling next to me) that people need to turn their lights down. The worst is the strobes on dark shared paths at night crew. They can't see where they're going with that light, at what point do they realise this?
Some of the new e-bikes (heavy pedelec types, undoubtedly ridden illegally) I see on the TPT have lights as bright as a train. I'm literally dazzled +100 m away and have to stop.
lesterama | 3 weeks ago
Not just the lumens, but also the legislation. Bike lights that aren't dipped are a menace.
We need to be like Germany, and only allow lights with beam control on sale. Otherwise we're just giving bike-haters another stick to beat us with.
I've been using Ravemen front lights for years. I won't ever use a strong non-dipped light again.
Secret_squirrel replied to lesterama | 3 weeks ago
Of all the things cycling needs it's not more legislation or ammunition for another culture war.
It's a meaningless trivial problem - get some perspective.
quiff replied to lesterama | 1 week ago
I have two StvZsvotVso compliant lights, or whatever they're called, but there's still room for human error as they need to be angled appropriately. At what *I think* is the right angle, I no longer get oncoming pedestrians shielding their eyes - but the flip side is I can be alarmingly close behind an all-in -black pedestrian in the unlit park before the beam picks out their ankles.
Nighttrain123 replied to quiff | 3 days ago
Get night vision goggles.
Nighttrain123 replied to lesterama | 3 days ago
I wonder if shrouded lights would help? A narrowed beam?
andystow | 3 weeks ago
These things and other cheap ebikes are the culprit around me. At least they have lights, but there's no beam cutoff or even brightness settings.
They have much brighter lights than the one that came on my wife's Townie Electra, which cost more than twice as much.
Slartibartfast replied to andystow | 3 weeks ago
Yeah, I'm seeing a lot of super bright front light on town bikes (electric or analog). Presumably there's a way to tip a front light down, but no one seems to.
Nighttrain123 replied to andystow | 3 days ago
It doesn't help that most of these e-bikes are actually classed as motor vehicles and are ridden illegally in UK.
bobbinogs | 3 weeks ago
Same goes with car headlights for those of us road riders.
Pages
