New cassette - new chain at the same time?
As I use my bike on forest roads and so on as well as tarmac, I am going to swap my 11-32 cassette for an 11-34 to see if that's a better option for me.  Not sure whether to stick a new chain on at the same time or not bother.  And wondering about the chainrings too I suppose.  Drivetrain is Tiagra 4700 and has done just under 1300km.
11 comments
Shades | 1 week ago
Normally if I change the cassette, I'm ready for a new chain; rule of thumb is 3(?) chains per cassette when the chain checker reads 0.75.  I recently changed my cassette to a larger one which necessitated a new medium cage rear derailleur; new chain as well.  Front chain rings didn't seem worn.  Shifting was great (no noise) when I set it up on the stand, except when I went out on the road there was an annoying meshing noise in the 2 lowest gears (ie small chain ring; large cassette cogs) which I guessed was coming from the chain rings (meshing at a different angle to the previous setup?); fitted new ones and all good.  Downside of changing single components where as some people prefer to let it all wear down and change the lot (chain, chainrings, cassette).  If the cassette and chainrings have done some decent mileage and you shop around online for some components (incl chain), then it's a reasonably cheap DIY change (cheaper than the LBS) to get nice crisp shifting.
Judge dreadful | 1 week ago
Not if you've kept an eye on the chain stretch. If it's within the limits of a stock stretch checking tool, there shouldn't be a need for a new cassette. If you've run the chain to destruction, then yes, change the cassette as well as the chain. The cassette and chain will form a 'handshake' of wear over time. Changing one without the other will force a new partnership, and during the time that's happening, you'll get a bit of accelerated  wear on the components. However, keeping an eye on chain stretch, I can easily get 3 chains per cassette, which is handy, given how much chains and cassettes cost on my group set.
Joe579 replied to Judge dreadful | 1 week ago
Thanks, I'll check it 👍🏼
check12 | 1 week ago
cheap chain checkers are a bit naff, not all actually work, get a shimano one or measure with a ruler (not across the quick link if your chain has one)
Joe579 replied to check12 | 1 week ago
I got the Pedros Chain Checker Plus II based on a couple of reviews I saw, which suggested that it was a decent one.
Joe579 | 2 weeks ago
Many thanks - I will see if I can measure it 👍🏼
David9694 replied to Joe579 | 2 weeks ago
You might want to get a chain checker for that (Chain wear indicator as referred to in the article).
Joe579 replied to David9694 | 1 week ago
I've ordered one cheers
Rendel Harris | 2 weeks ago
Not necessary unless your current chain is stretched and/or worn or if it's so tight you need longer to fit the larger cog (shouldn't be as you're only going up two teeth). I know the pro mechanic/racer mantra is generally replace chain and cassette at the same time but we don't all have team budgets or sponsored supplies - I tend to run a three chains to one cassette replacement ratio without significant deterioration in shifting performance. Chainrings should last far longer - at least the lifespan of two cassettes if not more. I have been told by a mechanic that a heuristic is new chain every 2,000kms, cassette every 5,000kms and chainrings every 10,000kms but obviously that depends on usage and type.
Cayo | 2 weeks ago
It's certainly good practice to fit a new chain with a new cassette, but if you're concerned about dumping what might be a perfectly usable chain, the simple question is whether the existing chain is worn. If not, go ahead and fit just the new cassette. But fitting a worn chain will risk one or both of chain slip or premature wear of the new cassette.
The only other consideration is whether the larger cassette would need an extra link. I'd guess not, unless your existing chain was already shortened to a very tight tolerance, in which case it's definitely time for a new chain.
