Shimano GRX rubber hood replacement
A few weeks ago I came off my gravel bike and put a big hole in the top of one of the rubber hood covers. I have bought a replacement pair but on inspection it looks as though fitting them without removing the levers from the bars (and disconnecting the brake hose and shifter cable) is going to be difficult, as the rubber is going to have to stretch a lot in order to pull over the lever body. Can it be done without permanently deforming the rubber, and if so using what technique?
Cheers
3 comments
Jimmy Ray Will | 2 years ago
As mentioned, alcohol based, or similar, hand gel / santiser plus a good bit of elbow grease will get you there.
Another trick would be to leave the new hood in direct sunlight for 10-20mins before application to encourage it to expand.
In reality its not as difficult as you expect, the biggest challenge for me was using enough santiser to enable movement, but not too much that I couldn't grip the hood.
Good luck!
Cristox | 2 years ago
I have done it to my Ultegra levers without removing anything but the old cover. I used rubbing alcohol to make the cover a little slippery and then pulled it over with force. No deformation.
Never use silicone spray or similar. The rubber will swell and deform.
Hirsute | 2 years ago
p98, 99
https://si.shimano.com/api/publish/storage/pdf/en/dm/GADBR01/DM-GADBR01-...
To remove and install the bracket cover, remove the brake hose and shifting cable from the lever, then remove the lever from the handlebar.
If possible, you may also remove the brake caliper from the frame and leave the brake hose connected. You can then pass the bracket cover over the hose and caliper to remove/install it.
Logo
Looks like your ad blocker is on.
We rely on ads to keep creating quality content for you to enjoy for free.
You can subscribe to road.cc to support us and turn off ads for good
Continue without supporting us
Choose your Ad Blocker
  • Adblock Plus
  • Adblock
  • Adguard
  • Ad Remover
  • Brave
  • Ghostery
  • uBlock Origin
  • uBlock
  • UltraBlock
  • Other
  1. In the extension bar, click the AdBlock Plus icon
  2. Click the large blue toggle for this website
  3. Click refresh
  1. In the extension bar, click the AdBlock icon
  2. Under "Pause on this site" click "Always"
  1. In the extension bar, click on the Adguard icon
  2. Click on the large green toggle for this website
  1. In the extension bar, click on the Ad Remover icon
  2. Click "Disable on This Website"
  1. In the extension bar, click on the orange lion icon
  2. Click the toggle on the top right, shifting from "Up" to "Down"
  1. In the extension bar, click on the Ghostery icon
  2. Click the "Anti-Tracking" shield so it says "Off"
  3. Click the "Ad-Blocking" stop sign so it says "Off"
  4. Refresh the page
  1. In the extension bar, click on the uBlock Origin icon
  2. Click on the big, blue power button
  3. Refresh the page
  1. In the extension bar, click on the uBlock icon
  3. Refresh the page
  1. In the extension bar, click on the UltraBlock icon
  2. Check the "Disable UltraBlock" checkbox
  1. Please disable your Ad Blocker
  2. Disable any DNS blocking tools such as AdGuardDNS or NextDNS
If the prompt is still appearing, please disable any tools or services you are using that block internet ads (e.g. DNS Servers).
Logo
