Good Morning all,
I’m currently looking at an Argon 18 Krypton, but am confused with the sizing; I currently ride a size 54 Cannondale SuperSix Evo, I am 5’10’ with an inside leg of 31 inches. Looking at the Krypton sizing and geometry, a small seems to be the closest fit. I’m not in a position to try to the bike out before ordering.
Could any Argon 18 confirm if this sounds about right, and the frames come up larger than normal?
Thank you,
Ian.
9 comments
CXR94Di2 [2739 posts] 4 months ago
Looking at the tech specs you would need a 'Medium' 54-56 to nearly match frame dimensions of the 54cm Cannondale- You didnt say which year is your super six?
https://geometrygeeks.bike/bike/argon-18-krypton-2018/
https://www.argon18bike.com/uploads/files/techcards-a18-2016-eng-krypton...
https://geometrygeeks.bike/bike/cannondale-supersix-evo-2013-2015/
https://epic-cycles.co.uk/cannondale-supersix-evo
There is about 7mm between 'reach' the Argon being longer (shorter stem would correct)
'Stack' virtually identical
head angle 0.2 deg difference.
54-56 Argon is your size, if your current bike is a good fit
IanS82 [2 posts] 4 months ago
Apologies, it’s a 2017 SuperSix Evo.
 The Krypton would be a 2018 model.
Thank you for your reply and help, it’s appreciated.
The Canondale over the years has changed very little apart from a few millimetres here and there.
I still think its 54-56 Argon is the correct frame bike to compare.
I always check reach, stack, head tube length to compare for bike fit.  Head angle and overall wheelbase determine handling characteristics.
AfterPeak [161 posts] 4 months ago
I am the same height as you and when I tried one in the shop they sized me a medium frame. I didn't buy it in the end but hope that helps
Thank you both, appreciate your help.
Ian.
PRSboy [567 posts] 4 months ago
I am 5' 9 and have a medium frame Argon 18 Nitrogen, which fits me very nicely.
A beautiful bike.
AfterPeak wrote:
A beautiful bike.
It is one of the better looking aero bikes IMHO, and feels great to ride.  Fast but surprisingly comfortable, handles beautifully through bends.
Looks after me too - only this morning I had a big moment at over 20mph when I swerved hard to avoid a big branch sticking out of the hedge, hidden in the shadows.  Hit a pedal on the floor, thought I was going down but miraculously it straightened up with no drama and I was on my way.
All in all, highly recommended, but they seem to fly under the radar in the cycling press.
gbzpto [133 posts] 4 months ago
I am usually an M but when trying one had to down size to an S. Had to put a 70mm stem on as well .I wanted to like it but Ended up not buying one. It just felt too stretched.
