- Cross country mountain bikes
- Tubeless valves
4 comments
I'd echo the views above; spinning is a great work out but I'm not sure it is close enough to proper cycling to keep everyone motivated. If you have the space at home it may well be worth considering some rollers - they're pretty cheap and help enormously with bike handling, balance and core strength. Combined with a sufferfest video or similar you may find these to be more 'fun'.
Sounds like it is worth a try is tight for time or weather turns bad again - thanks guys - any other thoughts also appreciated
I've also gone to spin class when the weathers bad, or been time constrained, and found it useful. It's intense, I usually sweat soak a base layer through completely. The saddles are padded, but not too huge, I find. The classes I go to you're standing up/sitting down and leaning forward and back all the time anyway.
Having someone shout instructions, I find, is an easier way of actually doing interval training, without the hassle of traffic/hills/corners/cars obstructing what you're trying to achieve.
I think it's useful, and do use it (although more when the weather's bad or the evenings are dark) for intervals. The classes I have used are typically 40-60 minutes, but they are very intensive, so I think even 40 is worthwhile. (I've not tried 30)
There does seem to be a growing number of cyclists using them - identified by the padded shorts and cloppy shoes - you'll need SPD cleats to take advantage of this, otherwise it's toeclips/straps in your trainers as I do.
A note of caution though - the Kaiser M3 bikes typically used for spinning classes show a wattage figure on the display. I think it's BS, partly because it seemed a bit optimistic of my power output, but mostly because some service guy turned up to the gym and 're-calibrated' the bikes. More like he just tightened the nut marked 'resistance' as far as he could, because now the gear/revs I can maintain is entirely dependent on which bike I choose, whereas they all seemed fairly consistent (if over-estimating) before.
As well as padded shorts and a drink, I wear a proper base layer (you'll sweat a lot), take a towel and wear mitts to stop my hands slipping off the bars (see above re sweating!)
Have fun.
