25 comments
Well the bike is back together. The new bottom bracket was indeed the same size as the old one, so it fit in fine
except for the left cup(?) - it would not screw in no matter how many times/ways I tried it (yes, I know you turn it in the opposite direction of the pedals to tighten) I have used the cup from the old bottom bracket and it fits, but doesn't sit flush to the frame - it has screwed in far enough to be recessed by about 5mm.
The pedals turn (always useful) so I'll find out tomorrow how it cycles.
Have you checked for any thread imperfections? It's amazing how the smallest easily-filed-off burr can prevent connection.
I'll have a proper look tomorrow.
The new one is plastic though, which seems strange.
Being the cautious type, I think i'll throw the old one in my bag, along with the tools, just in case...
Made it into work okay - so the new bottom bracket works.
Have checked for thread imperfections - simply ran my nail around the thread and couldn't feel anything. It also tightens the correct way (apparently you can get alternative threadings), so I think i will try fitting it again this weekend. I'm not happy having the threads exposed with the old cup recessed.
Definitely a learning experience!
Thanks for all the advice everyone.
BB threads get pretty gunky - in extreme cases, they need to be re-cut with a tap tool. For more average cases, a wire brush run around the threads can clear out debris that fingernails won't. A smear of suitable grease on the new cups too, of course.
Go very easy with the nylon/plastic lockring on the non drive side, they're very easy to strip. A square taper BB with a locator pin can help or if the tool you're using has spanner flats you can clamp the tool through the BB using a wheel quick release.
Whilst unlocking my bike this evening at work, I remembered my square taper bottom bracket installation, been so long, those things last so much longer than the hollowtechs, the non drive size has no flange and mine have always had a couple of threads showing, not a huge amount, but it never went fully in.
I have over 13500 miles on my SKF, and can't detect any wear. They come with a ten year warranty, which includes the bearings.
A couple of things spring to mind.
Firstly, and I'm sure this is the case because you mention pedal direction, the drive side cup tightens anti-clockwise and the NDS conventionally clockwise.
Second, try unscrewing the drive side slightly, does that then let you fully screw in the NDS cup? If so then back out the NDS side a little and tighten both sides alternately. If you happen to have two BB tools then you can do it simultaneously.
Certainly you have the right replacement BB as the dimensions printed on it match. When it comes to square taper to a certain extent the axle length isn't a factor in whether it will fit - for example fitting a longer axle merely moves the cranks/pedals further apart which can help reduce heel strike on chainstays or simply with comfort/efficiency. That probably accounts for the difference in what you found fitted vs what was listed in the specs by Halfords. It will be down to supply chain issues probably and simply what was available at the time. If the old BB NDS lockring is metal then you can probably use that instead of the nylon/plastic one. I far prefer them as they're less likely to strip. Getting one of these tools if you're regularly working on ST BB's is well worth the reduction in risk of stripping either splines or knuckles.
https://www.ebay.co.uk/itm/193931593764
I tried it with the drive side in and with it completely out, but I was a little pressed for time. I plan to try again this weekend when I hopefully have a little more time.
Really useful tip to use a quick release bar to hold the tool in place - I had been wishing for a third hand!
I am slowly accumulating more tools as I go. Some have been handed down from my dad, some I had from doing plumbing work around the house.
This is a good instructable on building a tool although the Sealey one I linked is probably cheaper and you can stand on the handle if it's particularly stuck (not an issue in your case).
https://www.instructables.com/Seized-Bottom-Bracket-Removal/
Another recommend for doing your own maintenance - but buy the right tools - you will probably find you can get the spares and the tool for less than the price the LBS will charge for fixing it.
You can also do your repairs/maintenance when you need and not have to wait until they can fit you in... and you have the tools ready for next time.
Upgrading a Voodoo bike is a fool's errand. Eventually you will have replaced every part except the frame, and the frame is the worst part of it. Just save money you would spend on upgrading it towards a good bike. Cheers.
Unfortunately it's not an upgrade, rather a replacement.
I have been really happy with the Limba. It was a cheap bike (not sure when £500 started being cheap!) but it's been really nice to ride.
As with everyone, I dream of replacing it with something much better, but funds dictate that!
Looks to be a perfectly good commuter. Voodoo bikes are usually pretty good and well thought out for our riding conditions. Huge clearances, external routing, space for rack and guards, what's not to like? I had a Bizango for a while which was a great intro to MTB for me.
Voodoo bikes are perfectly adequate entry level machines, and there's no harm in tweaking the spec a bit if you feel like it. Obviously bike snobs are going to sneer at them, but there's a lot of people who laugh at bike snobs too. It's not the bike, it's the rider.
I didn't expect to be giving a review of the Limba, but:
If I won a substantial amount of money on the lottery, would I buy a Limba? No. Don't be silly.
As a first foray into a cycling commute that is a mix of roads and muddy canal paths - I have been very happy with the Limba. I've managed to fit a pair of SKS Speedrockers to it. I've added M520 clipless pedals. I put Schwalbe anti-puncture tyres on it - dropped from 37mm down to 32mm. I cover the 11km commute on the bike in the same time it took me to drive it.
I am most definitely a cycling convert. I didn't realise how much I hated sitting in my metal box staring at the lights of the metal box in front of me. On my bike I have a set of people I say hello to every day. I get to see the sunrise. I see wildlife. I once saw a deer bounce across the canal path, jump into the canal, swim to the other side and scramble out. Not once did I see that in my car!
Yes, it's absolutely effing FABULOUS!
What a lovely response (rather better than the original passive-aggressive comment deserved), a great reminder of why we need to keep pushing for more and better infra as so many people would join the ranks of the "converted" if they had the chance to experience the joy and freedom of riding, and they're only going to do that if they feel safe.
Mmm. Bile duct playing up? Any danger that one day you might offer a constructive, upbeat - dare I say - helpful comment, Mr. Need?
Sounds good, you appear to have the right length axle and the right shell size for the bottom bracket, to be able to get it out you have the correct tool.
Even if there is 1/2mm difference it's not going to make too much difference, maybe a slight adjustment on the front derailleur, if you have one.
Enjoy doing your own spannering, there will be mistakes, some expensive, but you will learn from everyone of them. And such a feeling of satisfaction.
Thanks - fingers crossed it all goes back together tomorrow!
I am very much in the "fix it myself" camp, but am frustrated that I can't find a list of the parts in the bike. It feels very much like "search for ages and then pick the one that looks the closest"
I need to find my local bike shop and make some new friends...
The problem with bike sellers is they like the flexibility of fitting substitute parts when it suits them. This keeps the supply chain active and, dare I say it, is an opportunity to hoick the price a little. It also means supplying a list of all the parts on a particular bike is slightly inconvenient for them but can be really, really inconvenient for the owner. But hey, no-one ever lost money by annoying the customer.
If, or when, you get deeply into cycling you may start to fit whole groupsets to your machines. It's what most of us do 'cause it looks pretty and the parts should gel together well. Another advantage is that you get to know each component and can easily identify replacements, or if the missus allows, upgrades.
Keep pedalling.
I bought a Calibre Two-Cubed during lockdown which bore little resemblance to the spec listed on the website and was a lashup of various low-end Shimano MTB drivetrain parts. I guess the average buyer wouldn't have noticed but I did and they gave me £100 back which made it even better value than it already was.
Really? The closest I've got to that is fitting a matching gearset and hubs, (Ultegra, Deore XT) I used SRAM X9 gearset and cranks on one ... it's fun building a new bike with a good groupset, I've done a few including some very shiny Campagnolo, but I never felt that it would meet my specific requirements, or that my bikes needed added bling.
