Stelvio gearing (11-28 vs 11-30)
Hi all,
I'm doing a multi day cycle event (for charity) from Monaco to Zurich over a couple of bumps but most noticeably the Stelvio (from Borneo) and am not sure whether to use 11-30 or 11-28 (alongside a 52-36). I am 85kg with an FTP of 300.
I have an 11-30 already fitted (which has got me up Sa Calobra, Puig Major, Coll D'Honor, Coll De Sóller and Ballon d'Alsace in real life).
I'm 40, have been cycling more than a decade and have had the privelege of doing Valley of The tears, pico de la nieves and mount teide in real life (not on an 11-30 as it was a hire bike) as well as alp du zwift (under an hour) and mont ventoux (under 90 mins) on zwift with a wattbike.
Why do I want to change to 11-28 you may well ask... Well......i purchased am OSPW (Ceramic) from Ribble for £35 before realising it only works with 11-28 (i.e not 11-30) and am attracted by the lower weight of 11-28 and the aesthetics of an OSPW (no idea if it works though).
https://www.ribblecycles.co.uk/level-ceramic-oversized-pulley-wheel-syst...
Would appreciate any advice/guidance please??
25 comments
Dnnnnnn | 1 year ago
Not sure I've much to add to this other than to agree with the others. You didn't say specifically at what point the Stelvio appears in your schedule but with multi-day, multi-climb tours, it's always worth erring on the cautious side. You might have a bad night's sleep, dodgy dinner, the weather might be bad, etc. It's not like a Sunday ride where you can skip it, shorten it, change the route or time...
Daveyraveygravey | 1 year ago
I did the Stelvio from Bormio about 3 years ago, I think I would put it down as my favourite day ever on the bike!
I'm 80 kg, have a 52-36 and 11-30, I would have been 55 then.  Stick with the 11-30, you'll be using it!  The hardest thing I found about the Stelvio was the top, the last 3-400 m of altitude nearly broke me.  I'm lucky enough to be able to do the Blockhaus in the Apenines quite often, which tops out at 2100m.  I'd never really thought about the thinner air going up there, but it seemed much more noticeable at the top of the Stelvio.
Take lots of kit.  I did it at the end of August, after a fortnight on the Adriatic beaches regularly at 35 degrees.  The Stelvio in Bormio was 6 degrees first thing in the morning!  I went in shorts and short sleeves, thinking I'd be climbing for 2-3 hours and would warm up, which was about ok.  I assumed by the time I came back down the day would have warmed up too, but it didn't.  I took about 45 minutes to descend, teeth chattering all the way...
Also, the weather can be horrendous.  I tried to do it 2 years before, they have Stelvio day at the end of August, no cars after 8 am.  When the weather is nice, 10k plus ride or run or skate up.  The first time I tried, it rained all day the day before, and was actually snowing on the day itself.  They closed the road to all traffic about a third of the way up, but still circa 2000 folk braved the elements to go that far.
Bikepool | 1 year ago
Thank you all for your comments, I really appreciate you taking the time to share your advice and experiences. Such a wonderful community of like minded legends!
I have decided to leave the OSPW off the bike until after the event and use the existing 11-30 on (or possibly use an 11-32 from a winter bike). When I get back I'll chuck an 11-28 on and fit the OSPW, should get me up most UK climbs I encounter.
Thanks again everyone.
huntswheelers | 1 year ago
I'm on the tools.... and sort a lot of Challenge bikes out ... it depends on your ablilty plus if you have the route with the hills profile fot the route....  Then assess your ability and then check a couple of scenario's on     http://www.gear-calculator.com/?GR=DERS&KB=24      including the tyre/wheel sizes.
Input the fields with your proposed gearing's and go from there. It's easy to say go this or that cassette but sometimes dropping a front ring down say fro 52 to a 50 does it better......  Hope you find the answer
bobbinogs | 1 year ago
I've often regretted not having a lower gear to click to, I have never regretted having one and not using it.
hawkinspeter replied to bobbinogs | 1 year ago
However, my old MTB (mainly used for shopping) has now got its front derailleur a bit stuck due to lack of use. I can still get it to change, but it involves kicking it a few times until it's in the right place.
Inder | 1 year ago
I am currently using the Ribble OSPW with a 53/39 chainset and 11-30 cassette with an R8000 medium cage rear derailleur. It works fine for me.
Bikepool replied to Inder | 1 year ago
That's really interesting to hear about it being used on the wild, thanks.
Is it okay shifting under load (I noted Terrence the tractors comment that they sometimes struggle) ?
Inder replied to Bikepool | 1 year ago
It's fine, feels a bit different than the standard one but I think that's because there is less lateral movement in the guide pulley than the Shimano version. Feels a bit more like a Campagnolo rear shift.
Cugel | 1 year ago
Many of us olepharts have ridden such climbs on the long ago standard bottom gear of 42X21 (or at best, 24). It can be done, although you do get geet big quads and glutes, as it's weight training via pedalling.
The requirement to be able to do this was no doubt a decent FTP (although no one measured such a thing in those days) but also a big dollop of what was then called stamina. With long days out and a long series of extensive climbs, the ability to go for hours at a decent power output is more important than just a good FTP.
Now I yam old and decrepit, I enjoy the lower gears on the climbs .... and even the sporadic help of an electric motor!  But all climbs are still possible as much because I can push pedals for hours as well as quite powerfully when needed.
So ..... I'm sure you'll have enough power to go up nicely graded Continental climbs with even 39X28. But 34X32 will be kinder to your sinews and joints, especially if you haven't trained for years with a 42X21 lowest gear.   1  What you really need, though, is that stamina - the ability to do many miles, every day with most of the time spent going up. (It takes only a minute or two to go down, or feels like it).
Me, I'd forget the big jockey wheels (a useless fad) and install a 13-32 cassette with a 48/34 chainset. No silly big gears are needed as downhill and flat bits are where you need active rest in preparation for the next monster hill.
What you might also find efficacious is a close ratio cassette - as many one-tooth jumps between sprockets as possible - to enable you to find your exact cadence sweet spot as you labour for 30 minutes up a perfectly graded Continental climb.
mark1a replied to Cugel | 1 year ago
Cugel wrote:
... and install a 13-32 cassette with a 48/34 chainset. No silly big gears are needed as downhill and flat bits are where you need active rest in preparation for the next monster hill.
A slight flaw in that plan is that OP is riding from Monaco to Zürich, those ratios might get a bit old on much of the remaining -600km.
Cugel replied to mark1a | 1 year ago
What does "a bit old" mean? Is there an obverse of "a bit young" and if so, what does that mean?   1
The highest gear of professional racer folk just 2 or 3 decades ago was 52X13 (a ratio of 4:1). 48X13 is not a lot lower.  Will the OP be riding at race pace (25- 27mph) on the not-climbing parts of that route? Or will he go a bit slower (not much) and admire the scenery?
Now, must I explain also that freewheeling downhill crouched over the bars with the knees tucked into the frame, rather than flailing about pedalling, will actually make you go faster than if you turn the cogs?
Ah yes, "a bit old" m'lud, I believe it's used as vernacular for "a little tiresome"
Regarding your gearing, I bow to your own experience, however mine is that my gravel bike (48x11) will spin out on descents much more readily than my road bikes (mostly 52x11), so again, if it were me doing the ride, I would want the taller gearing for descents and maintaining a decent flat speed with sensible cadence, and the shorter gearing for Stelvio. I would live without the close ratio cogs.
PRSboy replied to Cugel | 1 year ago
The reason it's good to have say a 50/11 on a bike in the Alps is to give a bit of resistance on the long descents, if not at higher speeds but when cruising down shallower sections. Pedalling can really help to keep warm, and avoid the dreaded 'heavy legs' when you get to the next climb!
Cugel replied to PRSboy | 1 year ago
For keeping warm, I likes the clothes. On the other hand, spinning at 120 rpm will also tend to raise a sweat.  1
Consider the advantages of no 11, or even 12, sprocket - more actually usable sprockets for going up the hills, which takes far more time and effort than going down them, I notice.
My own belief, all of which are infallible (oh yes they are!) is that 52X11 folk feel they need a top gear, like in their car, which they should get in as this is what you do with gears. I have seen some who use no other of their 22 gears, if they can help it, as being in "top" is regarded as cool or hot or summick.
PRSboy | 1 year ago
I've done similar multi day mountain events and I'd want the lowest gearing I could. The few grams saved on the pulley or lighter groupset will make no difference.
When I did Stelvio I had a 34/11-32 and was very grateful for it, particularly after a long day and a few days in the saddle.  The Stelvio is high and cold which saps your power.
I'm 65kg on an FTP of around 280 at that time. I generally run an 11-25, a 28 was fine in Mallorca but I will be putting the 32 back on for an upcoming Geneva-Nice.
Miller | 1 year ago
The Stelvio is very long, and it goes to very high altitude. That altitude will knock a chunk off your power output which will only get more pronounced the higher you go. This is not the moment to be thinking of how your bike will look. This is instead the moment to be thinking how to get the lowest gear possible because you will absolutely use it.
pkaro | 1 year ago
Get an 11-32 or even better 11-34 and swap your 36 chainring for 34. With your w/kg, the length of the climb and the length of your cycling journey in particular, you will be very grateful for 1:1 gearing, should you need it (newsflash: you will).
Unless of course you love cycling at 60 rpm, switching between sitting and standing every 30 seconds for the last 45 mins of the climb!
This is coming from someone at 83 kg, 340 FTP, who rides 50/34 and 11-32, and who lives in Switzerland.
Grahamd replied to pkaro | 1 year ago
I run 11-34 with a 50-34 and wouldn't go back, even if you don't need the extra gears all the time, just knowing they are there is reassuring. I don't think it is encouraged or feasible to have more than a 16t difference between the front chainrings though, so changing just the inner ring may not be an option.
Cugel replied to pkaro | 1 year ago
The 11-34 cassettes unfortunately come with the cog toofs starting 11-13-15-17 whereas the 11-32s usually start 11-12-13-14 and maybe 15. The latter is better for the fitter cyclist as the one-tooth gap in those higher gears means you don't have to increase or decrease your road speed by a large amount just to find your ideal cadence or anything near it.
One tooth jumps in such high gears are a pain in the legs.
mark1a | 1 year ago
I did this in 2019, aged 50, 85kg and FTP of 235W.
It wasn't a cycling trip as such (long story, family holiday tour via France, Belgium, Netherlands, Germany, Switzerland, Italy and back via France - the quid pro quo for my wife insisting on going to Venice was us entering Italy via the tunnel near Livigno, a stay in Bormio and me putting my bike in the van), I was bike fit at the time as just 3 months before, I had completed the multi-day N2 Challenge, a north->south 738km traversal of Portugal in 5 days.
My bike had 52-36 and 11-32, this was not so much in preparation for this climb, more that at home in Dorset, the local climbs are fairly challenging. However the sheer length of Passo dello Stelvio from the Bormio side, if I were you I would prefer all the help I can get. Although most of it is around 6-7%, it's over 20km distance, with a short 12%ish bit in the middle, and then the last few km are around 10%.
So my advice would be take the 30, leave the OPSW at home and enjoy the ride. Maybe even sell the OSPW and put the funds towards a 11-32 cassette.
Anyway, that's just my $0.02 worth, buona fortuna and all that and let us know how you get on.
Here's a gratuititous photo op - top one is a view back from around 2/3 of the way up, and the bottom one is the descent that awaits you if you're going over the top (I rode back to Bormio, if I do it again, I'd want to do both sides!)
Terence the Tractor | 1 year ago
I'd try the OSPW with the 30t cassette; the difference in radius between a 28 & 30t ring is minimal and guidances are always conservative (shimano being famous for being a good 4t under whats viable) you may find you get looks and gears that way.
Also; never tried OSPWs myself but supposedly they arent as good at changing under load - which maybe something to consider if youre going up a lot of mountains.
Secret_squirrel replied to Terence the Tractor | 1 year ago
This.  and if the OSPW doesnt work with a 30 look at the prices of a Wolftooth link (or the knockoffs on Ebay) they'll be cheaper than a new cassette.
Rendel Harris | 1 year ago
I've only ridden the Stelvio on the trainer but as a man of about your weight (though quite a bit older!) I'd say take every extra tooth you can get! How much weight will the new jockey wheels save you, 30g maybe? Take an inch less in your water bottle for the same saving...if in that impressive list of climbs you've done you never needed your lowest gear then maybe but Stelvio is fearsomely long, I think you'll probably be grateful for every gear you've got by the top.
If you really want to use the new system, have you checked it won't work with your 30T cog? Manufacturers usually state a maximum limit a few teeth below the real world limit, my Ultegra derailleur is only rated for 30T but it runs 32T quite happily and I'm told by the LBS that it should run 34T when necessary (sometime about the middle of next week if my knees keep deteriorating the way they are at the moment...).
Good luck on your ride, sounds awesome.
Simon E replied to Rendel Harris | 1 year ago
What Rendel said - forget the jockey wheel, that thing will do nothing for you when you're cross-eyed with oxygen debt at 2,750m above sea level. If an OSPW was so great Shimano, Campagnolo and SRAM would fit them to their top end groupsets.
Fit a 32t cassette. If your chain is even a little worn, fit a new chain too then lube it with an efficient lube.
If you are in a position to lose some weight without compromising your training - even just a couple of kg - that will do more for your climbing than any amount of fancy kit.
You probably know all this already but you asked, so...
Logo
Looks like your ad blocker is on.
We rely on ads to keep creating quality content for you to enjoy for free.
You can subscribe to road.cc to support us and turn off ads for good
Continue without supporting us
Choose your Ad Blocker
  • Adblock Plus
  • Adblock
  • Adguard
  • Ad Remover
  • Brave
  • Ghostery
  • uBlock Origin
  • uBlock
  • UltraBlock
  • Other
  1. In the extension bar, click the AdBlock Plus icon
  2. Click the large blue toggle for this website
  3. Click refresh
  1. In the extension bar, click the AdBlock icon
  2. Under "Pause on this site" click "Always"
  1. In the extension bar, click on the Adguard icon
  2. Click on the large green toggle for this website
  1. In the extension bar, click on the Ad Remover icon
  2. Click "Disable on This Website"
  1. In the extension bar, click on the orange lion icon
  2. Click the toggle on the top right, shifting from "Up" to "Down"
  1. In the extension bar, click on the Ghostery icon
  2. Click the "Anti-Tracking" shield so it says "Off"
  3. Click the "Ad-Blocking" stop sign so it says "Off"
  4. Refresh the page
  1. In the extension bar, click on the uBlock Origin icon
  2. Click on the big, blue power button
  3. Refresh the page
  1. In the extension bar, click on the uBlock icon
  3. Refresh the page
  1. In the extension bar, click on the UltraBlock icon
  2. Check the "Disable UltraBlock" checkbox
  1. Please disable your Ad Blocker
  2. Disable any DNS blocking tools such as AdGuardDNS or NextDNS
If the prompt is still appearing, please disable any tools or services you are using that block internet ads (e.g. DNS Servers).
Logo
