forum
Afternoon vent
I am about to have a rant about Halford's bike department. I will begin by saying I understand that this is entirely my experience with a single department and there will be plenty of excellent Halford's staff out there.
I bought my bike from Halfords a year ago. They offered "CycleCare" which was a bronze service after six weeks, then two silver services - one at six months and one at twelve. The silver service replaces the gear/brake cables - that alone was the cost of the CycleCare, so it made sense. Add that to the fact that I was just learning how to do bike maintenance - the whole thing was a no-brainer.
Six weeks passed and no contact from Halfords. I went online to book the bronze service - not possible. I phoned them "oh, you need to book an assessment, then they will book you in for the service afterwards." okay - not ideal, but okay. Bronze service went by without any trouble.
Six months passed, so I booked it in for an assessment again. Informed them it was due its Silver service. The assessment came back - my wheels needed truing. "We can book you in for Thursday". Sorry- no good. I use my bike for commuting. Booked in for a month later. I learnt how to true my wheels in that month. Not perfect - but better than they were. Bike went in and when I picked it up "We need the technician to true your wheels but he isn't in till Monday." Seems strange to book me in to get my wheels truing, if the technician isn't in - but they are okay anyway. "Oh and I had never serviced gear cables before, so the front one is a bit tight" A "bit tight" he says. No f**king kidding. It wouldn't budge. Got home, straight up on the stand and trace the problem - they had shoved the gear cable through the sheath and bent the sheath wires inwards, so they were crimping the gear cable. Not too bad to fix. Bike runs well again.
Another six months go by, so in for an assessment again. Guess what - wheels need truing again. No weekend slots for a month. Fine. Bike goes in. No call from them an hour before closing, so I pop over. "We need the technician to true your wheels, but he isn't in till Monday." What? You were just going to keep my bike and not tell me? No good - I need my bike on Monday. "ah well, the spokes are tight so I don't know what to do." other staff member "get spokes the same length, snip off the nipples and replace them" I keep quiet. Interested to see where this goes. "Yeah - I can give that a try tomorrow" Tomorrow comes, I go and collect the bike "the wheels didn't need truing, the tyre just has a slight bulge that makes it look like they do" - shows me the "bulge". Yup - I can see that. Noticed one before, but don't remember it being that bad. oh well. I ask about the front gear change "yeah - all fixed. gears are running perfectly now" I cycle home. Rear gears keep jumping up and down. Sigh. Have some lunch, then check the bike out. Flat tyre. I haven't had a flat tyre since I bought the bike. I look it over - the "bulge" is because he didn't put the tyre back on properly and one edge was overhanging the rim. It had "snakebite" and sliced a hole in the inner tube. Run off and buy some inner tubes. Tweak the gears to get them actually running perfectly.
And now, five days later, I take my bike out and front tyre is flat again. Quick change and off to work. I get 7km into my 12km route and I actually hear the rear tyre explode. Instantly flat. No sign of anything stuck in the tyre. Walk the remaining 5km to work. I have just had the back wheel off and no slices in the tyre - but a lovely 1cm long slice on the inner tube. The inside of the inner tube. When I look at the rim, the tape covering the ends of the spokes is now folded up - so best guess, they messed about with the spokes, didn't fix the tape properly and it has sliced the inner tube.
Never again will they touch my bike. On the plus side - I've learnt a heck of a lot about bike maintenance!
6 comments
Ride On | 1 year ago
I have found it nearly always cheaper and quicker to buy the tools and parts and do it yourself. You obviously get to keep the tools and skills you learn along the way. YouTube has a video on just about everything.
Absolutely hate waiting for the LBS to fit me in and finish the job. If I have the tools I can fix it at 11pm ready for tomorrow if I need to. Also buy a few cheap spares including brake pads cables and spokes £20 spent now is well worth it.
mark1a | 1 year ago
You're not alone. Many have had similar experiences, for example someone in my club was given their bike back with no hydraulic fluid in their brake lines (not Halfords I hasten to add). Thankfully they noticed immediately. I myself collected a bike and the (Shimano Hollowtech) LH crank hadn't been torqued up. My balls found this out halfway up a hill.
You're doing the right thing, learning to do the routine stuff yourself. I would recommend finding a really decent LBS you can call on for stuff that you either can't do, or is so infrequent it's not worth buying the special tool or whatever it may need. Then spend a bit of time & money there from time to time so they recognise you and will drop everything to sort you out if you're desparate.
I ended up making a bike workshop in my garage and doing a Cytech home mechanic course, so now I'm confident of doing most things, plus take a little pleasure in fettling a few other friends/relatives bikes if they can't get to or can't afford to get a professional to look at.
hawkinspeter replied to mark1a | 1 year ago
They didn't let that stop them, though
Steve K replied to hawkinspeter | 1 year ago
Chapeau
Steve K replied to mark1a | 1 year ago
This.  It also helps if you support the same football team as the owner...
One of the main reasons that I do almost all my own maintenance is the length of time that bike shops can take to do simple jobs. Most of the time, I can plan to do a job, get the appropriate equipment and then carry it all out within a couple of hours - bike shops invariably take days to do anything and weeks if they discover that a component needs replacing and they don't have it in stock.
I certainly wouldn't be trusting Halfords with working on my bike judging from various reports of their staff.
Logo
Looks like your ad blocker is on.
We rely on ads to keep creating quality content for you to enjoy for free.
You can subscribe to road.cc to support us and turn off ads for good
Continue without supporting us
Choose your Ad Blocker
  • Adblock Plus
  • Adblock
  • Adguard
  • Ad Remover
  • Brave
  • Ghostery
  • uBlock Origin
  • uBlock
  • UltraBlock
  • Other
  1. In the extension bar, click the AdBlock Plus icon
  2. Click the large blue toggle for this website
  3. Click refresh
  1. In the extension bar, click the AdBlock icon
  2. Under "Pause on this site" click "Always"
  1. In the extension bar, click on the Adguard icon
  2. Click on the large green toggle for this website
  1. In the extension bar, click on the Ad Remover icon
  2. Click "Disable on This Website"
  1. In the extension bar, click on the orange lion icon
  2. Click the toggle on the top right, shifting from "Up" to "Down"
  1. In the extension bar, click on the Ghostery icon
  2. Click the "Anti-Tracking" shield so it says "Off"
  3. Click the "Ad-Blocking" stop sign so it says "Off"
  4. Refresh the page
  1. In the extension bar, click on the uBlock Origin icon
  2. Click on the big, blue power button
  3. Refresh the page
  1. In the extension bar, click on the uBlock icon
  3. Refresh the page
  1. In the extension bar, click on the UltraBlock icon
  2. Check the "Disable UltraBlock" checkbox
  1. Please disable your Ad Blocker
  2. Disable any DNS blocking tools such as AdGuardDNS or NextDNS
If the prompt is still appearing, please disable any tools or services you are using that block internet ads (e.g. DNS Servers).
Logo
